Been using K&N oiled air filters on our Spyders and Ryker. Have installed many on customers vehicles. Zero issues. I've run them on both trucks and cars with MAF sensors as well. (All Spyders have MAF sensors as does the Ryker).
This is what K&N says about this. They have done extensive research on this subject because the 'Issue' comes up to them all the time. The link below is just an introduction. There are sub-links within this first one that will take you to all their testing, if you want to go that deep.
A K&N filter will flow more air dirty than a brand new paper filter. This is of great interest to a Ryker rider as the filter on the right side supplies air cooling to the CVT belt. There have been some with clogged paper filters which greatly shortened the life on their drive belt. Again, the same accusation exists for oil buildup on the belt causing slippage. This is not the case at all. Yet the idea persists.
https://www.knfilters.com/maf/massair.htm
Just wondering if you could run a K&N on the belt side of the Ryker without using to oil. Clean it and install without the oil in it.
Have any of you ever had any issues due to the “oilyness” of K&N air filters? I’ve heard they can cause problems with the MAF sensor. Does a 2010 RS SE5 even have a MAF sensor?
About an hour's worth of research seems to indicate that NICOclub.com has about the same ranking as they give K&N. Depending on what you choose to believe of course. What was it that Mark Twain said about statistics? Oh, yea. Well, I'm hanging with K&N in all my vehicles anyway. With oil and filter changes including air filters, coming in now with recommendations of 6k+ miles on cages and 9.300K on spyders, I'm figuring I'll be $$$ ahead with reusable air filters at the end of the game. At least that's worked for me in the past. Wishing you luck with the choices you've made in the past and for the future.
I can see the cost benefit of the K@N but of course that depends on the environment the paper filters are subject to. If you monitor rather than just replace regardless that gap closes.
Performance gains are a doubtful claim given stock filters flow way more than required by their given application so rule that out, and that is a big perceived benefit that people get sold on.
Cleaning does degrade the K@N over time that may not be as readily visible as a stained or debris clogged paper unit.
What else..........oh yeah oil is finite, trees regrow:yes::cheers:
"K&N will not give you a performance increase. The benefits are, for most, a one and done install. And never having to worry about running a clogged filter."
Will assist or hinder performance with stage II? Monster recommended K&N.
If you make modifications that move a lot more air, the K&N has a higher CFM capability. If you need more CFM than the stock paper air filter provides. Then yes. You will see more power with the K&N. But the stock, paper air filter for the Spyder has more than adequate CFM flow through. So, with a Spyder in stock configuration, the answer would be no.
