Hate putting air in rear tire.....Hate it.
Same. I have the FOBO system, and my tire pressure has not changed more than .5 since I bought the bike several months ago. (Well technically since I changed the back tire)
Yes, I’m the same, Allen. Sure, pressure loss is only minimal, but for the sake of a few seconds before you head out, you can be sure that your tyres are not suffering from a slow leak that could well leave you stranded as you don’t have a Spare” on the Spyder.
Of course, you could still pick up a puncture on the road, but that quick check before leaving is reassuring.
Good point. I have fobo set to alert me at +/- two lbs, so I don't really worry about it that much.
So your FOBO alerts you whenever your tire pressure increases by just TWO (2) lbs when you're riding?? :yikes: :banghead:
You do know that your tire pressure is MEANT to increase by about FOUR (4) psi over about an hour's ride as they warm up to their optimal operating temperature, don't you?? :dontknow:
This increase in tire temperature and therefore the air pressure inside the tire is what allows the tread to actually warm up enough to properly do its job! And if the tires DON'T increase their temperature by about that much, it means they are OVER-INFLATED.
Just a 2 psi increase (instead of 4 psi) after an hour's riding means that (amongst other things) they won't be able to provide too much in the way of grip; they won't be able to get rid of water if the road surface becomes wet, risking aqua-planing; they'll be at significantly increased risk of punctures from hitting road debris &/or stones etc; and the suspension will be working over-time to compensate for the lack of compliance in the tires, giving you a quite harsh ride... :gaah:
But if they only increase their pressure by something LESS than 2 psi after an hour's ride, that's reflecting the fact that your tires will be GROSSLY OVER-INFLATED, and even on the smoothest of roads, the ride will be very harsh compared to what it should be as your rock hard tires hit tiny irregularities in the road surface & skip/bounce clear of the surface multiple times per rotation, hammering & wearing you, your spine & body, your fillings & dentures, and your suspension in ways they were never designed or intended to be pounded while also really messing with your tires ability to work properly for you and increasing the risk of abnormal wear patterns; giving you an even greater reduction in traction & grip; massively increasing the risk of tire failure/blow-out thru impacting road debris &/or pot-holes, etc; almost guaranteeing aqua-planing on even a mildly water covered road; and often severely compromising the tread itself, chipping and tearing minute (or maybe not so minute! :p ) chunks out of the edges of tread blocks & sipes etc, thereby destroying their ability to work properly for you and wearing a whole lot faster than they really should while they put you and all the road users around you at risk! :yikes:
Please allow your tires to warm up enough so that they at least have SOME CHANCE of doing their job properly - a 2psi increase or less after an hour's ride means they are over-inflated and isn't enough to allow that; while anything over a 6psi increase after an hour's riding is risking failure due to under-inflation! :lecturef_smilie:
Just Sayin' - Again! :bdh: :banghead:
You do like your bolds and caps, don't ya? ;-)
I just rechecked my FOBO settings, and misspoke a little. It alerts at -2, but +5
Back tire (Altimax 45) is set to 18 min, 20.0 recommended, 25 max
Fronts (OEM Kenda): 20 min, 22 rec, 27 max
But I'm REALLY glad this came up... I just learned that iPhones do not transfer over BlueTooth pairings, and my FOBO has not been synced with phone for 2 months (since I got a new iPhone!)
I think I'll have to manually re-synch each now. Gah!
