Has anyone solved the riddle of using Bluetooth and USB charging? BRP Connect...
cjr00
I would like to use my I Phone for music and maps AAANNNDDD keep it plugged in so it is charging also. BRP Connect says Bluetooth must be turned on and phone must be connected via USB, but doing that gets me nothing thru the speakers. Using only the Bluetooth connection do I get everything thru the speakers, but the battery (obviously) isn't being charged. I feel like I am possibly missing a step. Has anyone out there been able to solve this riddle? Thanks
Find a "data blocker" - it is just a small device you plug in between the USB in the glove box (on my RT-L at least) and the phone you want to use. Then BRP-Go does not recognize the phone, lets it charge, and you can bluetooth the phone to the bike. I think I got two blockers on Amazon for $6 or close.
I found I could buy a "Charge Only" USB cord to use, likely has those datablockers installed or they just left out the data cables. Same result, phone stays charged while connected and BT to the sound system for everything else.
Here is your cure for charging from Dave
