Has anyone replaced their own Lock cylinders?
The Spyder could be more complicated than others I have done. I have not replaced a Spyder ignition, but I have replaced the ignitions on Honda, Yamaha, Suzuki, and Harleys. With the ones I worked on you ordered the whole ignition with new keys. All the ones I changed were older, like pre-2005 motorcycles.
You should do some reading in the maintenence Manual and maybe it will give you some information.
I have also repaired some broken truck keys which the plastic head of the key broke into pieces and the coded disk fell out on the asphalt in a parking lot. It can be fixed for less than a 5 spot, but the dealers and the locksmiths prefer to sell you new ones for way more.
The only think I have done is replace a cable behind the Ignition switch, what a pain in the sack!!! Of course, I did it the hard way and didn't do my homework before jumping in the pool, came out bleeding like a stuck pig, but got it in. My suggestion to you is google it before you jump, or get the shop manual for your bike!!!
Good luck!
Ps: what are you trying to do?? Get extra keys the hard way, or do you have a bad cylinder?
