This is the Doc Humprey's rack that he used to sell. I love it. In the picture from the rear, it appears to conceal my license plate, but this was before having my air bag replaced on my F3T. I also used this on my 2014 RT. Works great and holds enough clothing for 2people for 5-6 days easily.
There is a nut that I used through the hitch where the ball would be, and it also had 4 U bolts that held it in place.This is perfect! How did you mount it to the hitch?
I love this idea. How does the heat from the exhaust effect things. Does the exhaust blow back on the contents mounted on the hitch?
Where’s the pics??**one more time:View attachment 196165View attachment 196167 https://pakitrak.com/ do have to contact them for spyder parts
(apparently remove from webpage)
Also Jt has the NHR https://spyderstore.com/index.php?route=product/category&path=66 was a vendor on home page:dontknow:
Good idea in theory. As has been said the hitch is mounted solid to the swing arm so there is zero cushioning from road vibration and bumps. That means anything fragile is going to get mashed. You only want to carry very durable, and preferably light weight, objects in it, because they will bounce.Has anyone put a cargo carrier on their trailer hitch? Wondering what it looks like, and if it made the byke drive any different? Thinking it might be a cost effective way to NOT have to buy a trailer. Pics if you have them!
Idaho is correct. In the above photo the distance the rack hangs out over the hitch will increase the torque load on the hitch. The 40/45 lb load recommendation for the hitch load is ON TOP of the ball. Use a fish scale and attach it to the back of your loaded rack and see how much down pressure it actually exerts on the hitch. It may surprise you.
Rivco products has one.
