Handlebar play
jtoro1
I discovered my handlebar play came from the u-joint at the DPS it was loose just by tightening the bolts I got rid of the half an inch play on my handlebar the dealer said they all do that BS now if I could find the upper part of the steering column that u-joint might be loose too. It has BPR loctite which is not going to be easy to loosen. I knew they don't all do that because I wrote a spyder with no play.
