Handle bars.
MOSESS
Hi guys and Gals. its finally time to do this mod if possible. I want to raise my bars two inches straight up. I don't need to adjust them or tilt them in any direction . I have not looked under the plastic as of yet I figured I would get some info and guidance first.
HANDLE - BARS
:yikes::yikes:...Question - why do think everyone here knows what kind of Spyder you have ? ? ? ...... Help us , Help you ....... Mike :thumbup:
handle bars
Mosess, I take it from your profile that you have a 2014 RSS; if so the RT bars will bolt right on and give you a more relaxed riding position and a bend @ your elbows.
Hello
Hi guys I own a 15RT-S I also own a 1994 ImpalaSS so that's where the SS comes from. Its been crazy busy here in north jersey with building projects so I could not get back you guys sooner. Ill go back and read some of the positive posts with a solution to the problem . some of you need to relax. and chill out. thanks
:shocked: This is something that has been looked at by a lot of folks in here...
I think that we've actually only had ONE person figure out a way to do it...
But I can't remember who it was! :opps:
(Mike knows him...)
He ended up adding the risers out at the end of the handlebar center section, and bolting the stub ends in place.
He also had to extend a whole bunch of wiring...
Good luck, and let us know how this project proceeds! :2thumbs:
Wow more research
Bob so some one has done it. very good. when the weather breaks ill look into removing some plastic and seeing what I can do. I was hoping some one that has done this mod would come forward...
RISERS FOR RT - ST
(Mike knows him...)
:yikes: .... I would have been glad to tell Him too ............ However I've been told to " CHILL OUT ", so that's what I'll do from now on..... just added another to my " IGNORE list " :roflblack::roflblack::roflblack::roflblack: ............Mike :thumbup:
For my Goldwing there were several risers available. They were nothing more than machined wedges with different angles and extended bolts. I think I went through 3 sets before I finally found the exact right one for me. Gotta believe something similar is available for the Spyder. If not now, coming soon.
Mike,
Who was it; that came up with a way to raise the bars?? :dontknow:
(I just can't remember... :gaah:)
I'm trying to find you the name of the one that did it... :banghead:
I reverted back to stock configuration a while back and don't have any decent pics of the setup. however it's not a difficult mod.
you need 2 pcs of 7/8" steel rod 4" long and a set of RSI risers of desired size. I think up to a 3" riser the wires will not need to be extended. I had 5" RSI risers and had to extend the wires and also the hydraulic clutch line as I have a SM5.
Thank you
Bob and quasi. thank you both for trying to find the info, this does save a lot of time. I really need to do this mod or buy the adjustable setup. Blue Knight you need to relax my friend don't take this to heart. I did not put my bike info in my first post. I have met you so if I say relax don't get bent out of shape. But if you want to ignore a member because they hurt your feelings .oh well. Mr Quasi if you find any pics or info I would really appreciate all the help you can provide. Again thank you. LOVE AND PEACE BE WITH YOU....
Amen brother😁
PM sent
The best of luck to you with this project! :thumbup:
(Take LOTS of pictures!)
