Handle Bar buzz
Malathion
I have a F3s , at higher speeds 70 mph plus a vibration occurs that will make my hands go numb, is this normal or can it be corrected.
Curious. ....
Only at that speed ?? does it go away below or above that speed ?? There are several reasons for the vibrations on there machines. Belts, engine (mounts) front end (wheel balance, joints, alignment etc) and harmonics. Your can have it checked out to see if it is out of the norm mechanically but the harmonics are a bit tougher. I avoid those speeds....:thumbup:
BAR ENDS
I HAD THE SAME PROBLEM. I FIXED MY BAR BUZZ BY PUTTING THE STAINLESS STEEL BAR END OFF ONE OF MY OLD BIKES. THESE ENDS I USED WAS OFF A 2011 CONCOURS THROTTLE MASTER ENDS. I HAD BEEN TALKING TO JIM AT SMOOTHSPYDER ABOUT THE BUZZ IN THE BARS. CALLED HIM BACK COUPLE DAYS LATER TOLD HIM WHAT I HAD DONE TO FIX THE BUZZ. JIM HAD A PAIR OF ALMOST THE SAME BAR END. HE INSTALL THEM AND FIXED A LOT OF HIS BUZZ. HEAVER THE BET
BAR BUZZ
YOU CAN PICK UP BAR BUZZ FROM A FEW DIFFERENT REASONS. I DON'T CARE WHAT KIND OF BIKE YOU RIDE,THEY ALL HAVE SOME BUZZ IN THE BARS. SOME HAVE MORE THAN OTHERS. STAINLESS STEEL BAR ENDS HAVE BEEN OUT FOR YEARS FOR THAT REASON. HEAVIER THE BETTER, YOU CAN BUY A PAIR FOR ABOUT $70.00. GOOD LUCK. CHEAP IF YOU CON PARE WHAT EVERYONE CHARGES FOR PARTS FOR THE SPYDERS.
