Hand Grips
fetermel
Wondering if anybody has found any softer grips for my 2013 Model STS ? Some that would relieve the numb fingers.
I added a pair of "Grip Puppies" over the oem grips. They absorb some vibration but more importantly allow my hands to have a lighter, more open grip. The grip warmers work just fine thru them as well.
If you want something that is softer on your hands and allows your heated grips to come through and is really inexpensive go to Spyderpops page and look at the handgrips he has they go on easy and cost less than 15 dollars, they also reduce road vibrations. or you can just call Spyderpops at 501 627-4008.
These are the ones that i use and really like them.
Cruzr Joe
Spyderpops Foam Grips
I ordered a set of Spyderpops foam grips for my new F3-S but could not feel the heated grips thru them. I removed them and will save them for warmer weather. The heated grips on the F3 may be different from the ones on the RT's.
Tricled has some foam covers that work really well, they're a site sponsor, check them out.
john
:agree:
These are the one's I chose rather than the Grip Puppies, and I really like them. They just slide over top of the OEM grips. If you buy two pair, they significantly discount the second pair. That's what I did, thinking that when the first pair wore out, I'd have a back-up. But the first pair is still going strong after two years.
My wife favorite.....
See the attached image. They are from Value-Accessories, one of our sponsors. I offered them to my wife for her birthday, and see love them, so does her best girl friend, our daugther... and so do I.... I will get a set for myself next spring.
Richard
Kuryakyn ISO Grips for use with GL1800 and Can-Am RT with OEM Heated Grips
Price: $89.95
Cruzr Joe
+1! I purchased mine from Tricled. Good for large hands. The heated grips work fine through them and putting a little hand sanitizer on the inside of the grip makes them slide on very easily. Once dry, just a few min, they won't slide at all.
Numbness
Softer grips are ok but I have a question,
do your fingers get numb when you drive
your car ?
If not then I suspect you are gripping the
handle bars to tightly, loosen up your grip
some, there is no need to hold on for dear life.
Give it a try
Dave
Hand grips
Just ordered two sets of foam grips from Spyderpops for both mine and the wife's, looks like they should work good.
