always young
I had a laser alignment done on my 2016 F3 Ltd at Route 1 motorsports in Palm Bay a month ago (7230 miles) and things haven’t felt right since then (500 miles later). It initially had a slight drift to the right which was the reason for the alignment check. I finally remembered to take a serious look at things after the last ride this weekend and I found that both front wheels have severe wear on the outsides of the tires along with scallop ridges facing to the center. I consistently run 18 PSI and prior to the alignment they were wearing evenly, also, I’ve never hit anything which would have knocked the alignment off. Here are some other things that I’ve noticed. Steering is very light, and I feel every ripple and bump which yanks the bars. The bike tends to jog side to side over small ripples and bumps. Steering is light when going around corners and it reacts very quickly then suddenly increases the turn action as if you applied more steering. At first, I thought the steering sensitivity had been adjusted causing the lighter steering. Can it even be adjusted? Also, can anyone give me the numbers that the wheels should be adjusted to (toe-in, camber etc)? I’m making an appointment to take it back in and have them re-do it and would like to know the numbers beforehand to compare them to what it’s currently set at. I’m suspecting that they’ll want to charge me again for it which I’ll ague against. They should warranty their work. I appreciate any input on this. Thanks.
