h/l shutter stuck
irvin48
bought a set of led h/l's and put them in yesterday afternoon. fortunately
i didnt throw the body panels back on. about 2 this morning i woke up
thinking"i didnt check high beams". funny how your brain works. so that i
dont screw things up , what do i do to unstick it. go to the gurus for info
when you are STUCK with a problem! ill take the lamp out as soon as i get
back to the shop from my bike ride.[good for old people with arthritis].
thank you for any help.!!--irv toms :bowdown::bowdown::bowdown:
Been there-Did that
Hi Irv. Yeah, it's just the way you stuffed the extra length of wire and that rectangular driver box back into the lamp assembly. The shutter mechanism is all at the top area. You'll see the two arms with the spring on each side of the lens area. You want to try to place the driver box more towards the bottom. So, just take out the lamp assembly and re-arrange things inside a bit. Video of installing the TricLED bulbs here. Even if yours aren't TricLED, the basic concept is the same.
SHUTTER STUCK
thanks doug. will take a look. everything i do on this machine turns into an event.
:bowdown::yes:
Irv I just did two different types of LED headlites ( had NO shutter issues ) ..... what brand / vendor do you have. ........ Mike :thumbup:
:bowdown::yes:
You're Welcome. You can move those arms up and down with your finger and see what parts to avoid, and see that everything is all clear when you're finished. That won't hurt anything.
its amazing what you can learn by all the little details of something after
a "whoops". i now know all the fine points of the shutter system, and
also where the 2 leftover bolts went from behind the h/l fairing 6 months ago! . all in all a good morning
thanks to you guys. the spyder community rocks!!!! as always.
again:bowdown::bowdown::bowdown::bowdown::yes::yes::yes:
hi mike . lets just say i now have led h/l's and let it at that. it was my own
fault that caused the problem.
we have never ridden at night but now we can be seen in the daylight.
