Just Doo Me
Recently wired in a set of H.I.D.S from Custom Dynamics and used Lamonsters step by step instuctions posted here.After doing the first one I compared it to the stock using the light switch on the r/s bar and found everything working good. Then did the second one and when trying it out it had no light from it so I switched the ballast and wiring between the two so I could see if it was bulb or ballast related.Well the one that wasn't working now lit up and the other that had before now didn't.I then thought I may have got a bad ballast as both bulbs had worked with the one.While figuring out what to do next I happen to hit the high beam switch and both lights lit,odd because the lights are single filament and the switch just opens the projector in the stock set up.I did try low beam and everything stayed working.I then pulled all the connections apart and made sure all was seated,everything working.Next time out there was a small delay on the one side is this normal? Rode for the first time this year to a friends and when leaving one was out again until using the r/s bar switch then both lit.Any ideas?
