ground clearance adjustment
lascar
HI Spyder women and Spydermen
I have change my front shocks for ELKA's and I want to know the mesure from both red parts of the shocks to adjust my ground clearance (see the picture ).
Have a good day and good ride on you Spyder !!!!!!
Mine came CowTown set at 8.5" from collar to collar and I have since gone to 9" but not for ground clearance. I think the adjustment is to control side to side movement and stiffen the front end so that the Spyder stays more planted in the cross winds and corners. If you are going to make an adjustment don't forget to loosen the Allen screw on the lower collar.
thank you bobbobtar ,I will do it now .
What was your setting when first installed, inside collar-to-collar including the spring ?
Mine also came at 8.5" and I tightened the ring 2 complete turns to get them stiffer which I like. they are now close to 8 1/4".
I have not mesure before .........
Now they are put at 9 cm from collar to collar and my ground clearance is near 11,5 cm like with the stock absorber.
Now I will play with the black ring to adjust the shock absorber movement .
Install shocks, put jack under frunk and you want to raise front of bike about 1/2 in. befor the wheels come off the ground. if not ether, tighten or loosen the springs equally to get that 1/2 in of travel. NOT the travel of the shocks, but of raising of the front of bike. I had to loosen 5 turns on mine, but I don't weigh much. Then I found that sweet spot on the bottom adj. at 20 clicks closed from fully open. Mine rides great now. This advice came from Cowtown this past week over the phone.
