Grips
billpowell
My wife rides a 2010 RT SE5 with heated grips. Does anyone know if the Kuryakyn ISO grips, p/n 6341 still allow the grips to be heated both low and high?
Thank you for your answers and time.
Bill
RT grips
Check out Lamonsters post about adding grips. The Kuryakyn's make the grip extremely huge. You will need a pair for the Goldwing with heated grips. If you use the 6341 you will lose the heaters.
Use Part#6183. I installed these with the throttle boss. Heat does work but not as well as before. I guess it has to transfer the heat thru some thick rubber to get it to your hands and it loses some heat in the process. They slip over the stock heated grips. You will need to do some trimming on the stock grips and the shifter button on an SE5.
These grips are very fat. I have big hands and like it. As I continue to "not get any younger".....the fat grips with the throttle boss makes riding more comfortable for me.
If you go with them, check out Lamonsters how to video.
Steve
