Grip Fits - does the Ryker use standard diameters for both grips?
sKiZo
Always a fan of the old style Triumph balloon grips. Wondering if the Ryker uses standard diameters for both bar and throttle sleeve? Drilling the ends for the mirror mounts should do it if the things will fit.
I think In motorcycle world there are two standard diameters, I'm sorry I can't remember the rykers but I know it's in the documents. I used a set of left over grip puppies I had for my triumph, worked fine. I also picked up generic set of bar end mirrors , and mounting hardware. Throttle sleeve have not done.
Looking at my orders on Amazon od 7/8 I think they are a bit thin on I'd for standard, but I was able to use 7/8 handle end plug.
any 7/8 motorcycle grip set will work the right hand side has a larger diameter to go over throttle slide
ive just fitted a set of Oxford heated grips to my Ryker the I had on my Triumph so old fashioned Triumph will fit without any problem
