Graphite in key?
viperryder
Has anybody used any kind of graphite in there key? Mine seems to be sticking and I don't want to gum up the works without at least checking with the WISE Spyderlovers. Thanks:banghead::banghead:
Either one..!!
Both work well. Just make sure the lock is not wet. Blow out with canned air or compressor. Then apply graphite or lock ez... :thumbup:
Locksmith Here
Locksmith here:
I would not recommend graphite it will gum up with the moisture and become mud. Caned air, and then your favorite, spray lube will do just fine. WD40 is not a lube,(the WD stands for water displacement) not a bad thing in the south where humidity is a problem.
Michael
