GPS finaly fitted
Trumpybob
Thought some of you might be interested in where I finally decided to fit my GPS. Didn't fancy fitting to the handlbars. The cradle for the GPS is screwed directly to the handlebar shroud with rubber spacers making up for the uneven shape.
Oh, and Scotty, thanks for your info about aux. power and the powerlet plugs. I hadn't thought of putting an aux. relay in the trunk. Will come in handy when I get some heated grips. Most everything else should be covered with 3amp fuse.
Bob
I like it! Great for us geezers with bifocals. Hope the sun doesn't glare too much or wash out the display. Not too keen about drilling the cover on our PE, however. I had considered it before, though. Easy place to screw down a ram mount or two. You'll be very glad for the auxiliary relay up front. As Tim Taylor used to say, "More power!"
-Scotty
