bluewoo
Went to Erie PA this weekend and when I went to unload the spyder the parking brake lamp was flashing, But the brake did release and I pulled it out of my toy hauler. After I got everything else set up I went back to the spyder and now the P brake will not release (!) still flashing. So I finally once packed a 12mm wrench and of course I needed it and removed the cable. I did notice how hot it was in the toy hauler and how hot the spyder was when this all happened, But after it cooled down a little I tried it (cable detached) and everything was normal again. * The motor was not moving to release cable, push PB button once just flashing push it again still flashing but would beep if turned off or tried to move yet cable never moved, when I turned on key the parking brake lamp would take longer to come on then start flashing*
Codes are:
Brake has been normal since then.........turn key on and PB lamp is on quickly not flashing..............
Thanks for any input and I know the dealer will say "cannot duplicate" BS so I better figure it out on my own.nojoke
Codes are:
