The drama continues,,,,
Today, I went to the repair shop to check on my tires. Both fronts were outside heating up in the sun as the outside beads had still not seated all the way around. I told the tech that based upon what I had read, he might have to pressure them up to about 80 plus PSI, sure enough, about at 85, bang, they seated all the way around.
The rear tire, surprisingly, went on far more easily. Tech just pulled the sprocket off and had no issues with it going on successfully.
So, I cart the tires off to the dealer to be balanced, since I didn't think the repair shop had the proper eqiupment to do an MC type wheel (did not bother asking, stupid me)
The Can-Am dealer takes a look, checks with the service guy who says no way will they touch them since they did not install them. More liability issues. O-kayyy.......
I call back the repair shop and inquire about balancing, which they say they can do only on the fronts because the rear needs to be stripped of all extra parts in order to be able (hopefully) on the balance machine. Back home I go and strip the back wheel clean. Back to the shop and drop it off.
Hopefully, all of this will be fixed tomorrow.............
