Got a code PO217
Jonnyvermont
I just got back from a 70 mile ride. As I backed into my garage, the screen was orange and said "HIGH ENGINE TEMP" alert or something close to that. I checked the code, and it displayed PO217. Anyone know what this means? It was hot out there... about 90 degrees. The temp gage was about 3 o'clock.
Thanks
P0217 = Engine coolant overtemperature. In short, you overheated. Check coolant level, check fan for proper operation, check radiator inlet & outlet for blockage. If those are OK, have dealer check thermostat and water pump. If coolant is low, check for leaks.
Thanks! I will check this out.
This forum is amazing. Very active, and full of great, passionate people.
