Gorilla Alarm
I have the Gorilla alarm and it works OK. I first installed it on a 09GS and when I traded it in, I Installed it into a 13ST. I installed it in the tail section both times. First instal in the 09 I learned that the alarm must be installed solid to the Spyder. Don't use the velcro that comes with it. The shock sensor just does not work worth a darn that way. When you set the sensitivity so that when people touch it, it goes off, heavy trucks going by can set it off. For that reason I use warn away mode. It just gives a single load chirp if someone touches it. Even in warn away mode if someone push down on the brake pedal full alarm will sound.
The next time I trade I will be going to an alarm with a proximity function.
I installed the Spy 5000 MC alarm (Got it for $89 on Ebay new). It's basically the same Alarm as Steve's Scorpio i900 (hooks up the same and has the same features). It was pretty easy. Only thing I did not even try to get working was the remote start and remote kill.
Bob
