Good To Go Transponder Location
guinness
Been looking at this transponder and the instructions for mounting it. Instructions show a round headlamp with the transponder located 3" up from the bottom. hmmmm.... I don't have a round headlight. Anyone else use a tolling transponder and if so, where did ya mount it?
Thanks
Not sure..!!
I don't use one anymore...no toll roads out here..yet..:banghead: but have seen several posts here stating they put them on the inside of the frunk lid with heavy duty velcro and they work fine. Worth a try...:thumbup:
I placed mine on the windshield and I have had no problems when I go through the sensors on the Tacoma Narrows bridge. But I have a RS and 25" windshield and I believe I put it about 3 to 4 inches from the bottom of the windshield. Also my transponder is the one that is the strip transponder. Not sure which transponder you have, but this helps if you have this one. good luck...
I have a triple pocket pouch on my dash, I keep mine in the far right pouch. It works great and no one can see it.
Justcalldon
It's a strip
I may use your system on my RT... Thanks!!!
