Thanks Dave. Do you know how much for the part?
There are actually several pieces to this heat reduction system. The four foam pieces have been combined into a kit, and there is also a heat shield. You will have to remove the glove box to install everything. The parts are listed in the parts fiche, under "Body Parts - Console), so I can't understand why your dealer couldn't find them. Some dealers have retrofitted the early RTs with these insulating panels under warranty...but if your dealer can't even find them in the parts list, I'm not sure I would want him to take my Spyder apart to install them.
219800172 FOAM KIT (replaces 705004427, 705004428, 705004429, & 705004426) $31.99
705004424 HEAT SHIELD $14.99
Yes, if you have a removable foam tray, you have the latest design...as well as the other panels and the baffle, which are inside the bodywork.Are you saying later 2010 RT's have this installed from the factory? My RTS was built in April 2010 and I do have a removable glove box tray. Is this the same thing?:dontknow:
The padded liner is part of the foam kit. It cannot be purchased separately now. Some dealers have installed the kit as a warranty item for the early RTs not so equipped. I couldn't say whether every dealer would do the same...or whether this was a dealer initiative, or something approved by BRP. Your blue RT should already have the foam.are you sure about BRP paying for RTs to have the foam kit and padded liner installed? or just the foam kit and heat shield portion and not the padded liner?
Supposed to keep (some) heat out of the glove box. Not sure if it helps the heat coming from the front of the seat, or makes it worse. My 2010 RTS did not have the kit.Thanks for all of the info Scott. Will the foam kit and heat shield help with the heat leaking out from under the seat?
[QUOTE=ThreeWheels;280980]I had the whole system installed on my RT by my dealer.
In short, if you have to pay for the upgrade out of pocket, it's probably not worth it.
