Glo Ryder uninstall
Stridersr7
So on my 2009 I want to take the top off and put a battery in it to make sure it all works. For the life of me I don’t see a screw holding the top on above the see thru glass. I see install videos and they always talk about a set screw. I see nothing
I'm pretty sure you can just pull the cap off but check with GloRyder.com. they added set screws to later versions but the O-ring pretty much keeps it in place.
On my earlier ones (2008 - 2011) I could get at the back batteries without removing the wheel. After removing the cap with the setscrews, the "guts" disassemble from the front and you can remove the set screws exposing the inside batteries on the backside of the guts.
I no longer have them. They are living a second life in the lower 48 somewhere.
