I was in the process of wiring my givi top case,and i had it working. Then my tailights and brake lights stopped working,the engine will not crank and it won't come out of reverse. I checked all of the fuses,found a 10 amp for turn signals blow,changed it,but still no tailights,no brake lights,no crank and won't come out of reverse.Any ideas?..All I did was tap into the white and black wire to connect my top box..I there something that overheats and then cools back down?,because I did have the lights on for a bit to check which wires to tap..
It now will start,but I now have a abs/vss fault with limp in mode scrolling across my cluster.
I went out a bit later,now there are no warning lights,no limp in mode,but still no tailights and brake lights..fuse 7 is good..I have three lights in back behind the seat..two small on both sides of the center stoplight..Is this factory or did someone add the center one?
I found a connector on right side by brake light switch.I can disconnect it and apply 12 volts and my rear lights wo
I finally gave up...drove it to the dealer in limp in
They only had it one day...my wiring job was correct,but when I replaced the fuse I blew,I put 1/2 of it in one location and the other spade in the location next to it....I never said I was smart!!!!...they found that and adjusted my parking brake at NO CHARGE!!!..AND I LOCKED MY SPYDER KEY UNDER THE SEAT WHILE I WAS TALKING TO THEM,AND HAD TO DRIVE 80 MILES ROUNDTRIP FOR MY SPARE..I THINK THEY FELT SORRY FOR ME.(I THINK I COULD STILL HEAR THEM LAUGHING AS I LEFT..
