Givi Bags and Lights
chuckd1947
Is it necessary to purchase a light relocation kit when installing the Givi Bags? If so, any recommendations.
Also where can you install the 12volt outlet power kit besides the trunk? Thanks
You don't have to have the lights on the bags, but I would recommend it. They operate seperately from the other rear lights.
I've seen lot's of folks with the outlet on their dash, but be aware there is a dedicated plug behind the installation point in the frunk.
Which Givi bags? If you buy their brackets, the Givi brackets include turn signal relocators. The BRP version has the relocation as part of the bracket mounts. If you want to add lights, or do more than move the turn signals, or if you desire an alternate location, you will need to get some aftermarket help.
Givi Leds
This is what I did besides using the Givi signal bracket. They are brighter than what the video shows.
Easy to do.
Contact Evan at ESI. He has a great set of lights, with good instructions for the Givi Bags.
Very bright, good disconnect for removing the bags too.
