getting towed
flea
will be moving a 2008 rs either on a car trailer or tilt truck , will need to winch it on either one , where is the best place to attach winch cables , there is no tow ball at the rear ,could winch from front or back
Not one spot but a loop through A arms on either side to a Y at winch cable. Tilting flatbed preferred.
I know you said you need to winch it on, but if it can be driven on, I think that would be preferable. Otherwise, what Bfromla said..... Jim
I replaced the nuts on the front shock bolts with lift rings available from Amazon. As said create a Y thru the shock bolts to pull with in an emergency. I also carry a tow strap. Never needed to use either.
thanks everyone , thought that would be the best way but as new to these machines best to double check
