Gauge pod
MOSESS
Ill be swapping out the temp gauge soon to install a volt meter on the right side. I know the I have to disconnect the fuel gauge. is there a dummy cover or some other useful gauge to install there. ready to roll on some of my winter mods thanks.
What you want is part #705003421, Gauge Cap. That is the blank used on the RT base model. You don't say you have an RTS or RTL but I'm guessing that is what you have, right?
I have a 15 RT-S. I am looking to fill the hole with a blank or another functioning gauge of some type. If I where to install a clock on the left where would I get continuous power. what have some of you put in that space.
Little checking..
There are many guages you can place there but it you are not interested in a guage the usb/charging port is the best...jmo..:thumbup:
a clock would be a constant drain on the battery.
Cruzr Joe
I have two USB ports in the center of the handle bars , I have the volt meter ready to go just want some thing else to fill the void but some thing useful. I know i mentioned a clock and that would be a drain. I could mount a small nav but I am afraid that it would grow legs and walk away when I am not around, Keep the ideas coming guys as I am at a lost on what to put there. thanks
Best ..
I don't know if there is a best . the unit I got was 25,00 bucks on Ebay. I saw some as high as 80.00, I thought that was a bit over the top so 25.00 was best for me..
I found this one on eBay. It's a Intellitronix. I have had it for 6 years.
