Gauge cluster
Let's see..!!
if no manual is available...there are two small slots above the cluster where the safety card is. By inserting a small bladed screw driver down just behind the bezel of the cluster you will release a tab. Pull the cluster forward then do the other side and pull the cluster out and disconnect...:thumbup:
Exactly. You have to "hinge" the top of the cluster down towards the handlebar as you remove it... I'm sure you know, the windshield comes off first.....
