GAS - regular or premium?
There was a thread several months ago where I posted a lot of data regarding the octane issue...if someone does a search, they'll find it...
The big debate without facts. Can anyone tell me what the octane rating means and what it does?
In simple terms The higher the octane the slower it ignites,it's needed in a high compression engine to control pre ignition. Somebody with better typing skills can explain it much better.
Note RT= 87 minimum RTS= 91 minimum, That's minimum you can go higher.
So breaking it down, lower compression, faster burn during the power stroke so the fuel burns completely prior to the "blow" stroke. If your fuel is burning slower, unused fuel will be pushed out the valves causing fouling on the plugs and valves.
The corollary, if your compression is high (and 12.2 is high), you want slower burning fuel. The LOWER octane will burn too fast for the power stroke causing pinging or knocking and loss of power, not to mention lower mpg's.
Since the engine is engineered for 91 or higher octane, that's what I'm putting in it. It might run ok with the 87 or 89, but eventually it will catch up.
'high' compression is a relative term.... Many engines that are considered 'high' compression spec 87 octane....
Run the minimum that the manual says. If you have knocking or pinging--- you need to raise the octane.
The RS specs call for min 87 octane, the RT specs call for min 91 octane.
That sounds about right for the compression specs.
:agree:Well Stated!:D
I burned 87 all last summer. Imma gonna switch over to 91/93 this year and see if I can feel any difference. As for the price difference, Spyder is considered a luxury item in my book, so if you can afford it, shelling out for gas shouldn't be an issue.
Are YOU saying that BRP is fibbing????? Perish the thought....
:roflblack:
Nope--- just passing on what others have stated. Dunno why there is a difference between what they list and what some have measured.... but I'm sure you can come up with another nutty conspiracy theory.
Add that one to your list......:roflblack:
I've filled with Sunoco super premium (93) the past two fillups and my GS Spyder is running just as good (maybe even slightly better) as when I fill with regular.
If they were CC'd, I agree they'd be static numbers. But why would BRP claim a much higher ratio in their spec's. Which they've posted in many places, for several years now. If it were not close to being true, wouldn't they get called out sooner or later?
I'm wondering if the 9:1 claims aren't dynamic compression estimates, which are based on cranking pressure, and are typically lower than static estimates, due to intake valve timing......:dontknow:
Hard to say, but then again those engines are made by Rotax.....maybe the air is thicker in Austria.:D
