Gas - I tried 93... going back to 87!
Sorry but this is BS. I have been through the fuel systems on a number of vehicles that have run nothing but E10 fuel for hundreds of thousands of miles. Squeaky clean. ALL fuel systems in the last many years have been designed for it. The only real problems have been in older engines with fuel systems containing materials not compatible. E10 gas containing ethanol does NOT turn to corn syrup. Dont wish to debate the fallacy of using it in the first place, but its not a detriment to modern engines longevity.
If a vehicle burns the ethanol fuel within a certain amount of time, your exactly correct that it won't turn back to sugar. But, let that fuel stay in a tank for an extended amount of time, untreated, and look at the damage it causes. My father is a mechanic, day in and day out. He has worked on cars that have sat for an extended amount of time, both carb and fuel injected. Injectors will crystalize at the injector nozzle and even crystalize in the lifters and seize them. I've seen it personally several times.
Yes newer vehicles will burn it, without problem. Just don't let them sit any long period of time. Ethanol attracts water, only takes 30 days to seperate from the fuel and will settle in the bottom of the tank. Then the pump sucks water first into the fuel system. Do what you want, I don;t want that in any of my vehicles that aren't driven consistently. For me, the ethanol free is cheap insurance or I'm using a stabilizer.
You post would be convincing......except that you blew it when you started talking about "lifters".
The fuel does not TOUCH the lifters.
So that little mistake puts your whole post in question.
Yes, fuel deteriorates in storage. E10 just goes bad a little differently and slightly quicker but is that because of the ethanol itself or because the gas it is blended with has a slightly different forumula ??
It is highly likely that those vehicles you talk about that gummed up while not in use would have done that with pure gas too. The result might have been slightly different.......but not much.
I have seen lifters crystalized. I know fuel doesn't touch them. I was just stating what I have observed in components that had ethanol fuel burned through them.
Not My Experience
I consistently get 2-3 mpg better mileage on my 2008 RS with premium fuel over regular.
You probably get mostly 87 octane when you select a better grade anyway, because the hose and who knows how far back from there is full of the cheap stuff. You would have to hang around and get behind someone who just pumped the good stuff to get a full tank of it.
"Good stuff" ? "Cheap stuff" ? I don't think these apply to different octane ratings of the same fuel.
My 2010 RT with the 998 also saw the same improvement; when running premium... :thumbup:
But my 2014 RT with the triple saw no difference in fuel mileage...
Many people live in areas where non-ethenol is not available and their vehicles still seem to operate. Stop the silliness. Do I use non-ethenol when I can get it? Yes. Is it available within 100 miles of me? No.
Crystallized? Into diamonds possibly? What does fuel have to do with lifters? Come on now this is BOGUS.
The requirement to retard ignition (premium gas does just that) is dependant upon elevation. Pure and simple. Anything above 4,000 feet really doesn't warrant premium gas just due to the principles of combustion. Less elevation the requirement is varied ... I would think that at sea level it is the most required.
I like premium cookies. :2thumbs: They taste better than regular cookies. :thumbup: Tom :spyder:
In the recent past there have been a few threads about type of gas to use in Spyders. I have a 2010 RTSM5. I have used 87 octane since I purchased it 2 years ago and got a steady 32 MPG. After reading all the comments about gas I decided to try higher octane so over the last few weeks I put in 93 octane. My driving habits are the same and the area where I drive is flat. After 4 tank fulls with the 93 octane I have calculated 28 MPG, a loss of 4 MPG :yikes:and no noticeable change in power. But a change in cost at the pump to the tune of $0.30 more a gal. So as you can assume I will be going back to 87 octane.
well stated and I agree with you on the 87 octane. I just got my 2018 RTL (my 4th Spyder) and I have run on 87 octane with all of them. Some of our NISR (Nebraska Iowa Spyder Ryders) club members won't go on longer rides if they know there is no 91 octane available along the way??? I also tried the higher octane thing and found no noticeable difference on performance and MPG. enough said... :lecturef_smilie:
BIG F
Sorry but it's not that easy.
First, higher octane does NOT "retard" the ignition.
It suppresses PRE-ignition from high compression. It also helps keep the mixture from exploding instead of burning in a controlled manner.
Regardless of your octane, when the spark hits, the mixture burns.
Then to your elevation claim......that is true but only because the thinner air makes for a richer mixture and a rich mixture isn't as prone to either pre-ignition or spark knock. Other things can cause a richer mixture too.
And other things can, and DO, make higher octane unnecessary, most notably engine design.
