Green RSS
Here is how I mounted and hardwired power for my Garmin Zumo 660 onto my RSS.
I used the Garmin windshield mount to mount the unit to the bike. Easy install and removal. :thumbup:
To supply power to the Garmin, I cut the end off of the power cord for the windshield mount (cigarette/power point plug). After attaching terminal spades to the two wires, simply plug the spades into the female connectors of the existing power point wiring. This is the pre-wired hook up that Can-am supplies, in case you want to install the Frunk power point. You can find the wiring zip tied to the passenger side frame just behind the Frunk. The connectors are covered by a rubber boot.
You have to install a 3amp fuse in the #3 slot in the fuse box. There is an extra fuse inside the fuse box cover. I routed the power cord down thru the dash, by removing the safety card (pull out thing) and feeding the wire down the slot that it was in.
I zip tied all the wires to make sure they won't come into contact with anything they shouldn't and it's done!!
You have to remove the passenger side cover and the front passenger side piece that runs along the side of the Frunk.
