Garmin GPS
spyderdreams
I have a Garmin nuvi 760. Is it possible to connect it to my RT w/audio & convenience and cb so that I can hear it through my helmet?
If it has an audio output jack, you could run a cable to the MP3 input in the rear cargo compartment, or if Bluetooth, you could do the same via a Bluetooth receiver, but it will not have the same priority as the factory unit, and will be muted by the other communications, unless you disable the mute function in the setup menu. Then it will still be reduced in volume.
