h0gr1der
So, today I was installing my new Garmin Zumo 595LM. Take the Tupperware off, cut the AMP Superseal off the installed Zumo 550 and pulled the wire from the interior of the bike.
Soldered and heat shrink in place the new Superseal on the 595 power wires. Plugged it in before snaking the wire through the body, installed the 595 in the cradle, and key on check. No go on the Zumo. Rats.
Checked for power to the cradle. Power makes it to the downstream side of the Garmin installed 3A fuse (pulled fuse out enough to check with meter). No power on any of the cradle pins. No 12VDC or 5VDC anywhere.
Did verify ground is making it through. Looked for the cradle wiring diagram and pin-out, only found the 660 cradle diagram. Does anyone know what the pins are for the 590 or 595? They're the same I'm told.
So I guess Can Am isn't the only ones subbing out to the cheapest bidder. From what I've read this is an issue with the Garmin cradles. I like it when a product works exactly like is supposed to. I'm wondering if I'm going to regret buying Garmin? The GPS itself works great, but if the mount is inferior?
