Garmin 590
Fatcycledaddy
Does anyone know if the Can Am supplied Garmin 590 is lifetime maps.
I was told that it was when I purchased the bike, and yet when I tried to update mine with the new maps this am, it said I had to pay for them?????
Is this correct? :dontknow:
Check the serial # if it ends with LM or has LM in the # somewhere it is Lifetime Free Maps
if it says LM and will not let you update call Garmin customer service and talk to them.
I had to do this with mine and they sent me a Lifetime Maps Card
If you bought a RT Limited it should be free Lifetime Maps, if you bought a RT or RTS it might not be LM
Cruzr Joe
The way I understand it is that all Zumo 590's supplied by BRP are Lifetime Maps. Zumo 660 older versions are not lifetime maps but newer ones are. If it says LM in the model number. It is lifetime maps. Call Garmin.
Cruzr Joe
Thanks, it is a RT LTD and that is what I thought. It has always loaded the new maps until today when it wanted to charge me.
Thanks for the input, I will call Garmin.
Take your 590, open the battery cover, lift the battery at the opposite end from the plug and check the model number. If it says Zumo 590 LM you're good to go. If it says otherwise, call Garmin OEM Product Support, 855-607-2536, and explain the problem.
I just checked the Garmin site and it looks like they never a Zumo 590 model that was not a LM version.
Are you using the latest version of Garmin Express?
You need to register it with Garmin. (The original owner) It will then allow free updates.
Jack
Jack
It was registered. On the phone with Garmin right now and they said that "yes it has lifetime maps".
They are working on it to see why it is not being honored.
Thanks for all of your input!
By the way, seeing how it cam with the Spyder, there is a OEM number at Garmin to call for help. That number is 855-607-2536 if any of you might need it. Calling direct just cuts out one more step, one more person to talk to, and one more phone transfer.
Thanks again!
