On my 2019 f3s se6 when shifting at medium rpms it shifts smooth but at high full power shifts it histatates i every gear is there and adjustment for that not to happen ?I am not hitting the rev limiter
At a guess, unknowingly you are backing off the throttle slightly, confusing the computer with a TPS reading change.
As I understand it, the shift unloads the drivetrain by momentarily killing the ignition. Fuel flow is not altered as it is too slow to respond.
Twist the grip hard to the stop, so as to know it is not being even slightly closed, and start grabbing gears.
I'm not trying to be difficult PMK, but I believe you have this the wrong way round. If unburnt fuel is allowed into the exhaust it will explode as soon as the ignition comes back.
I suspect that the OP has the throttle wide open in any case, hence his query.
With respect PMK, you use terms like 'as a guess' 'typically if' 'possibly BRP...this or that.' It would be good to have facts rather than ifs and possibilities. Can you produce them?
If I had a Spyder that had a definite bang under hard acceleration I'd be concerned rather than equating it to high performance sports cars on the track, and looking for the cause. But that's possibly just me. :cheers:
Well then, facts, and I held off on mentioning this previously.
Facts,a short while back, while discussing this with longtime Spyder owner, and a factory trained technician that has worked on many Spyders at an awarded Spyder dealership, Kenny Butler agreed the unloading of the drivetrain for a shift was accomplished via an ignition cut. Short of asking the guy that designed the system, I trust Kennys training and words, along with the telltale bang in the exhaust system as ignition cut.
I have no concern about an ignition induced fuel relight under hard acceleration.
The proverbial ball is on your side of the net, do you have facts to validate your opinion the shift is accomplished via fuel cut?
Update on my post 14: I contacted Jase @ ECU Xtreme here in Aust ([email protected]) who is the go-to boy for BRP wizardry here. His reply to the 'fuel or ignition cut' discussion while gears change on the SE6, which PMK and I were sharing with you all is: Cut is done via the whole ign so both fuel and spark are cut. In the old days it was fuel cut.
There - were we both right or were we both wrong? But we're all smarter now. :yes:
Ride safe and keep banging away at WOT :yikes:
