pontow
I searched a lot for this particular fitment question and did not find a great deal of information.  Based on what I had found, I went ahead and pulled the trigger on the following combination.  The good news is that IT FITS!!!
2015 RT-S with stock windshield
Stock single antenna
Show Chrome 41-155 Tour trunk rack
5/8" riser kit for the rack
Nelson Rigg Full Cover CAS-370
This particular cover has reinforced openings for the stock antenna and also for another antenna on the left (which I believe would be the optional CB antenna if your bike is fitted with this). As you can see by the attached pictures, the fitment at the rear of the bike is pretty full but it is not tight and the cover pulls easily into position around the bottom of the bike all around. The windshield does need to be in the lowest position.
This cover was selected because I used to have some covered parking at work but that has changed with some recent construction. With the bike sitting outside all day, constant Southern California sun and also directly in line with a municipal airport flight path about 1/4" mile away, I wanted to cover all of the painted parts. This particular cover is pretty substantial but it does take up quite a bit of room in the trunk. I'll use something different for travel and day trips.
