Fuel vapors! Still....
cyclerider
After a second visit to the dealer, (where they kept the bike for more than 2 weeks twice) and a "software update" boiling fuel is still a major problem.:banghead: I have a 2013 RTS purchased new last year. (No miles) It is stock and under full factory warranty. For me this is a bit more dicey because BRP claims the recall has fixed the issue. For all or most of you here, you removed the cat, wrapped pipes, installed heat reflective material, etc. If I do that BRP will do nothing for me, and void the warranty. They have told me so. Because it is not a BRP approved fix!:banghead: I am calling BRP tomorrow and demanding nothing less than a replacement bike. Period. I love the concept of this bike. But, for the money, it is a poorly executed piece of crap!! How can a machine like this, after R&D leave a factory? I have two choices. Call BRP and see where it gets me. If they fix or replace it. Great! If not. I just fix it myself and lose the remainder of my warranty, on a very questionable bike. Not happy at all.....:mad::mad::mad:
Seems odd. Most people from what I have read are happy with the fix. Maybe it is something else.
If BRP claims that the issue has been solved: what does your dealer say? Can you get the bike to show the existence of the problem to them? :dontknow:
If they can see the fuel boiling, and smell the vapors: they can go to bat for you with BRP...
Good luck! :thumbup:
Vapors
I had all the nasty fuel problems with mine pre-recall. I had no confidence in the dealer where I bought it so I had another dealer do the recall work. I did nothing to try to fix the problem on my own, my machine is totally stock in that respect. Since the work was done by a very good dealer all the problems are gone. There have been horror stories of halfassed recall repairs on these machines. Sorry to say you might be in that group. If you can get it done right you will be a happy camper. GOOD LUCK.
Agree with the above. Some 2013 owners on here have reported that their dealer did not perform the entire recall. IIRC, it was related to the fuel system part of the modification. In other words, the recall work was much more than the scoops.
Some of the 2013 RT owners had the recall done and the dealer put on the scoops but didn't remove the acoustical panels to let the cool air in. You could check that easy enough.
Sorry to hear....
But does sound like you need new eyes on the spyder. You may need a evap canister change or other fuel related change. You could run it by another dealer /shop and see if they did do what they were supposed to do. Hope you can find the people to get it done. Did you open a case with BRP..?? and adding pipe wrap and heat shields will not void your warranty...:banghead:
Agreed
I don't have much confidence in the dealer I took it to. So I will call BRP and then set up an appointment with a different dealer. Thanks!
. I am thinking maybe the dealer did not properly re do the fuel system. When I talked to BRP they specifically told me that heat shields and pipe wrap is not an approved BRP solution. Although I agree with you that this should not void the warranty. Yes, new eyes is what I need. I am taking it to a different dealer.
Vapor smell is one thing. But I would say that most, if not all, Spyders experience boiling fuel.
It's not just Spyders. It's most gasoline fueled vehicles. Especially motorcycles, etc., where the tank gets heat from the engine. Gasoline does not have to get that hot to boil. It is much more common than people realize. That's because you usually can't see the fuel. But the vapor recovery system is designed to siphon off the fumes (which occur whether the fuel boils or not) and burn them.
Since many, if not most, have been very happy with the BRP fix. I'd say something has not been done correctly (or at all). Hope you can get it fixed right.
Gasoline can boil at as low as 104F. It depends on the grade and what additives are in it. Boiling gas happens a lot on motorcycles.
If the fuel vapors bother you, do what I do - fill the tank right before you get home. I have a gas station a half mile from the house. A couple gallons of cold gas does wonders at cooling the tank and doing away with fumes.
If you don't have a gas station near you, keep a 5 gallon gas container in the garage and use it to top off the tank when you get home - no more fumes.
Hate to say it but: how can you prove all the warranty work was was done ?:shocked::popcorn: You may need to visit other dealers & get them to look at more than a computer file of your vin number:banghead:
I am still seeing the fuel vapor pour profusely out of the charcoal canister!!!!
I do realize that cool fuel will bring the temp. Down. BUT! If I am spending this much of my hard earned money. I should never have to do that.
Yeah, your canister is probably toast by now, too. If you're also seeing a lot of liquid coming out that hose - before somebody comes on here and tells you not to overfill the gas tank - that's not it. The gas in the tank is being force evaporated with all the heat. Fuel vapors are just like water vapors in that once they cool down below their boiling point, they condense. So if you're seeing condensate coming out the hose, it's a pretty good probability that the canister is already soaked. And besides just the smell, it's flammable, too. It would be wise to get to another dealer.
I believe you can download the recall and everything that should have been done to correct the problem. check to see if everything was done and if not bring it to the attention of BRP and the dealer.
I am not seeing the condensate like I was before the work was done. I am in the process of (waiting for a call back from BRP) having it sorted out with BRP. Thanks!
I have spoken with BRP and this is probably what they are going to tell me. Go to another dealer. This will be the last dealer visit for this boiling fuel issue. I am going to speak with the service manager only on this and demand they go through the recall work with a fine tooth comb. Also, it will be a different dealer. Thanks!
I am sorry to say that your fuel is probably going to boil regardless of what you do. You may be able to reduce the severity and frequency. But you're most likely never going to eliminate it.
It's not a boiling fuel issue, per-say. The fuel in my Spyder boils at times. And so it is with probably every other Spyder, and most, if not all motorcycles. I understand that people are horrified by the idea. But only because they have no idea how common it is. Yet escaping vapors are not a problem on most Spyders, even so.
You should have no vapors escaping whether or not the fuel is boiling. But fuel vapors will be generated in the fuel tank whether or not the fuel is boiling. Concentrate on controlling the vapors and you will find your solution. Insulating the fuel tank from exhaust and engine heat will help. But it will not completely resolve the problem.
Then don't. I was simply trying to help with an easy, cheap solution.
Personally, I'd rather not have a garage fuel of fuel vapors - and if that means adding some gas to my tank, so be it. It is simple to do and my garage doesn't stink of gas fumes.
