Just been reading on the 1330---it says PREMIUM UNLEADED--is this a must? I use regular unleaded in my 2012 RTS-SE5 and have had no issues but do use a fuel additive bought from my dealer. I am curious.
Thanks ahead of time on my education!
BRP also recommends you use their BLENDED OIL in your 1330 Ace motor Spyder for 9000 miles ................and that's LUNACY ..........but that's about everyone's opinion EXCEPT BRP's.........Mike :roflblack:Use premium and save your money on the fuel additives. Its a wash. Their is a reason they recommend Premium and I will spare you the long desertation. You got to ask yourself--Spend $25-30,000 for the Spyder and then chinz a few cents a gallon on fuel when the owners manual tells you to use premium??
JACK
..................I think you are confusing LOW quality fuel with a LOW Octane rating. They are different things...............................JMHO.......Mike :thumbup:The engine as designed and tuned requires 91 octane or better. BRP states this on the emissions label under your seat.
That said, the engine does have protections to keep from harming itself should the owner use a lower quality fuel than required. Performance will suffer and its not advised long term. Using lower quality fuel will not immediately harm your engine. It will protect itself dialing timing back for the lower quality fuel.
None of our vehicles get Exxon products, fuel or lubricants for business and ethical reasons. They are not a tier one gasoline anyway.
You are going to get answers that are all across the board on this one.
We have three grades of gas here in Alaska. 87, 89, and 90. All five of my :spyder2:'s seem to run best on the 90. I always felt they were a bit less "snappy" when fueled by the lower octanes. This includes 4 Rotax 990's and the new 1330 engine.
We do not deal with ethanol additives here, so I am talking straight gas.
When given a choice, I put the highest available octane in the tank. When I can't choose, I fuel and go anyway.
Mileage wise, maybe a mile or two less per gallon on lower octane.
First time I've ever heard that opinion. What do you consider a tier 1 gasoline brand?
What is a tier one gas? In our area the fuel is piped in to a distribution center -- all the stations in our area receive gas from the same refineries that are hooked to that distribution center --
the only difference is the additives they add to the tanker when it is receiving the gas --
