Fuel filter part numbers, save some money!
kdp1308
BRP # 709000100
Walbro # 125-199
Wix # 33095
The BRP part number at least for my Spyder is 709000100. It actually uses 2. One goes between the charcoal canister and the purge valve. I didn't replace that one. It should only see some gas vapors.
BRP used this filter on many different models not just Spyders.
When I took the old one out it was made by Walbro and part number 125-199.
I searched for both of those and ended up buying one off of ebay for $15 including shipping.
The one on cheap cycle parts was $17 plus shipping.
The one on ebay said it was a Walbro but when I got it, it was a Wix.
When I looked up the Wix number I found out you could get those for about $8 including shipping. You could probably find them cheaper if you looked around. They do look exactly like the original one.
Also, I did buy a bunch of stainless fuel injector clamps to replace the crimped on clamps, which I hate by the way.
Hopefully this info will be helpful for some, especially since they are deleting all the old messages.
Keith
BRP # 709000100
Walbro # 125-199
Wix # 33095
Keith
Keith,
Been exploring changing mine too, and for my 2014RTL I see BRP Pt. # 219800056. Is the # in your post for a different Spyder?
Good to know
most auto parts have them just need to cross reference them. I got mine at O'Reilly's but don't recall the brand....Though I found the oem was clean after 6 years. Do use 91 and seafoam. :thumbup:
Ray, from Keith's avatar it looks like he's talking about a 2013 or older. The PN you gave is for the fuel filter assembly which includes the filter and two Oetiker clamps, while the filter alone is 709000100. Note the assembly is cheaper than the filter alone. There also is no fuel filter in the emission system plumbing on a 2014 RT.
It is a 2013 RTS. I did find various fuel filter cross reference sites but BRP numbers don't work. If you want to use the Oetiker clamps you need a special tool. The filter I have is all aluminum and looks like most car filters only smaller. I think they use them on many small engines. It is an all aluminum case that is for 3/8 ID fuel line. The overall length is 3.5". The body is 2.0" long and 1.25 dia. I can post a picture if needed.
Keith,
Ray,
Yours will use the Wix 33095, or the Napa 3095 (same filter as both are made by Wix). I used the same filter on our 2014 RT.
Les
Jaybros - Thanks for the reply. Just FYI...the fuel system diagram and subsequent part number description in my 2014 shop manual shows part #27 - with the number I show. Of course I realize that this is probably the only error ever noted in documentation for Spyders (LOL)
I STAND CORRECTED !!!!! :-(( Just looked at the diagram again and it does show BOTH numbers with the one showing "AssY" - which I didn't take to mean "with clamps". Sorry.
