fuel doors
rays hell
Will anyone be at the rally in Maggie Valley next month installing fuel doors ?
Thinking I would like to have one but don't want to cut my seat n fear of ......
Check out how I did my install, in the My Mods, or DIY. it is easy, if you can use a tape and a brain at the same time, it a piece of cake, really worth it.
I did find one wrinkle, my door is black. If you park with the sun hitting right on it for awhile, it gets hot, nothing to create a hazard, other to your leg while you ride off and your leg is resting on it.
Little checking..
check with BLUEKNIGHT911, he is very good at that but I don't know if he will be at Maggie valley...:thumbup:
:agree: Mike installed mine, and did a great job! :clap:
To be 100% honest: There's NO way, that I could build up the courage to do the job on my own. While he was cutting the seat cover, and poking hot nails through it :yikes:, I was just trying to NOT throw up!
The hot nail thing is just Mike being too cheap to buy a Dremel tool. With a Dremel, and an oz. of common sense its a piece of cake. Some people can't change a light bulb, but that doesn't mean that it is "too scary".:banghead::banghead: But then again if you are ladder challenged???
TOO CHEAP !!!!!!!!!!!!!!
Dear Bill, you are an A- hole ..... I have two dremel's ..... the reason I don't tell people to use that method is because if they don't have a Dremel ....they might / will just pick up a regular drill .....which is slow speed with a drill bit that is not meant to cut sideways ...... Soooo what will happen is they will end up pulling the threads under the vinyl and ruining their seat ...... A HOT NAIL WON'T DO THIS ...and most everyone can make a hot nail...... I may be considered cheap by some ..... BUT I'M NOT STUPID ..... I'm just trying to prevent people from making a BIG mis-take ...... Something you don't seem to give a DAMN about...... and Yes I'm a bit ticked off by your thoughtless post ........Mike :thumbup:
Guilty as charged and you are totally justified:yes: I was just jerking your chain and I did get you to explain that if you have a Dremel, its better than the hot nail, caveman approach. So IMO get a Dremel, or a blow torch to heat up the nail. Or heat up the drill bit, a little more control.Do you still need to heat up a 2" piece of pipe for the actual hole??:banghead:
