Fuel Door Question - lock or no lock
Biscuit
I picked up a fuel door without a lock to install on my 2017 RT.
For those of you that have installed the fuel door without a lock do you think you should have gotten one with a lock?
Thanks
Rod
Thanks
Rod
I've mounted a few dozen doors to RT & GS seats.... not knowing exactly what type/brand of door you have , I'll just generalize my answer …. Without the lock, the problem is how to keep the door closed …. if it has a Spring hinge it will be fine ….if it doesn't ( and I did one that had no lock or spring ) you could add a very small magnet with a corresponding piece of metal that protrudes from under the Ring …. I did this by EPOXYING the magnet to the door and epoxying a small piece of sheet metal to the ring …… it wasn't the best looking , but you couldn't see any of it with the door closed anyway....If you can tell me what you have and where you got it , maybe I can give better advice ……. good luck …. Mike :thumbup:
:agree: While the lock provides a measure of security: it's most effective function is to keep the door closed for you.
As long as your door has that covered: :clap: :thumbup:
Let's face it: the lock could be easily circumvented with a screwdriver anyway...
Choices, choices
if it is spring loaded and keeps closed on its own or you add a closing magnet as BLUEKNIGHT911 has done it comes down to how safe you feel that no one will pinch your gas or put something in your tank...:dontknow: I see or hear nothing in that respect and you don't have much gas to steal anyway....:roflblack: I think they look better without the key slot....:thumbup:
I myself don't see the need of a lockable fuel door. I did put on my last Spyder, a 2015 RTS and it was lockable. I regretted my decision cause now you have to keep up with another key. I've got way too many keys especially if you pull a trailer. Now you got a trailer lock and tongue lock etc. I have never heard of anybody messing with a gas tank or adding anything to your gas on any Spyder.
In sixty years of driving vehicles without locking gas doors or gas caps only one time, as I recall, has someone siphoned gas out of the tank. Some things in life that COULD happen, but probably won't, are just not worth worrying about.
I confess. I was the one who siphoned gas and I am sorry. I did it once and regret it. But, I was only 16 and learning life. BTW, I got a big gulp of gas while sucking on the hose that made me sick for a week..... Jim
IMO: A lock on the gas cap or fuel door is not really a necessary thing. Most people wont waste their time going through the siphon thing for less than five gallons.
And if they do...we are not out that much.
The only reason you regret it is because you did it right alongside a church where the Almighty could easily watch you! He's never let you forget, has he?? :roflblack:
