Frunk not shutting tight.
The frunk on my RT will not shut tight. Can the lock be adjusted?:spyder2:
There are two bolts with 10mm nuts on the latch. Loosen the two bolts and move the latch up/down until aligned correctly then tighten up. Make sure there is a little space between the hood and body when closed otherwise it will scuff the paint over time. Mine was way too high when I got my Spyder RT LTD but now it's perfect.
Before you adjust the latch, check to see if the thrunk liner lifted the weatherstrip anywhere (if you have a trunk liner).. Also check to see that the microswitch lever isn't bent an holding the lid up on that side. Both have happened to me.
Thanks worked great.
