Yes, there is an adjustment to the RT front trunk latch.It will have trouble latching or opening, especially electrically, if it is too tight. If you look at the latch, you will see two 10 mm bolts that attach it. Slots there allow adjustment if these bolts are loosened. There is an adjustment procedure in the shop manual. Lubrication also helps. Like on your car door, these bearclaw latches do not like to be dry. Also, especially if you have the RTS with the trunk liner, look to see that the trunk gasket is properly seated all around. It is easy to accidentally pop off a corner, leading to trunk latching problems.
