cnl414
I have a 2013 RTL that I'm having a problem with. Hopefully someone here can give me some guidance.
I can open the frunk with the electric switch without a problem but when I try to open it by the key it takes several tries before it will finally open. Then after opening it with the key and not the switch, it will open every time without a problem. But, if I then use the electronic switch again the key won't work for several tries.
Has as anyone had this problem before? My electric switch has broken in the past and if it breaks again I want to be sure that I can use the key. As it is now I'm afraid the key is going to break off in the ignition.
Thanks in advance
Charlotte
Thanks in advance
Charlotte
