Frunk/Cargo unit lower bolt
SpyderSteveFL
Does anyone happen to know the part # or size for the 2 lower bolts that hold the front cargo box / frunk in place? Mine seem to be MIA and I can't find them on the parts diagram. Pretty sure its a hex flange, maybe an M6 but need to know length for sure.
M6 x approx 30mm but the length is not that critical as it threads into a nut with nothing behind it to block a slightly longer bolt. Yes they are hex head.
6mm x 20mm, grade 8.8, flanged head, gold cad finished
Not sure if a 30 may punch a hole in the bottom of the plastic frunk.
20mm is oem length.
THAT BOLT
20mm is oem length.
:agree: ...... M6 x 20mm ............ But it can't punch a hole in the bottom ..... it's in a horizontal direction ....... and you can get them at Home Depot or Lowe's ...maybe a local Ace etc......
better option
Thanks guys! So it looks like that would be CanAm part #207662044.
Home Depot - Lowe's - Ace hardware etc...... probably have a M6 x 20mm - grade 8.8 Hex head bolt for lots less, that's easier to deal with because it's a HEX head........... Mike :thumbup:
Steve has some accessories planned. I was the one that pointed out those bolts were not installed.
I explained to him what the bolts were, flanged hex heads 6x20, even removed one from our RT, photo'd and texted to him.
Before I did all that, like Mike, I advised hitting True Value.
His choice where he buys them.
