PMK
I check both our Spyders 2013 RTS and 2018 RTL. The 2018 had only small amount to change. One wheel was toe out and the other toe in. I set the toe in equal on both sides. What a difference, it even rolled better.
The 2013 was toe in properly on one side and toe out nearly 3/8" on the other. Changed th settings and test drove for a few miles. Better but set it back up on jigs to dial in a little more.
Lindsey`s directions work and seem to be repeatable.
Took everything down to the dealer and showed how it works. He said it was too simple but liked it.
If you are the type rider to notice details in setups, yes, when toe is correct, not only is handling improved, but they roll much more freely.
