Good point, it DOES matter whether you have 14" or 15" wheels so we should each specify, though the reader can probably tell if the year of the Spyder is mentioned.Those bikes with 14" front tires seem to like pressures in the 17 to 19 psi range.
The 15" front tires like a little bit more (20 to 21 psi), due to the shorter sidewalls...
On our '14 ST-S I've found 20-22 lbs feels best for the fronts, and 28 in the rear. I prefer a bit more responsive steering, and don't like it to roll on the outside edge of the front tires when cornering hard.
