Front Spring Stiffeners Available
Since returning in October from "Spyder in the Smokies", and with a brand new mod installed on my 2014 RTS, I have rode close to 1500 miles with them in place and these are going to work well. This particular mod stiffens part of the spring, making the suspension more firm. There is a way to set it at 3 different levels of stiffness. The package comes with 4 stiffeners (2 per side) and can be used in either (A) position (1 unit) or (B) position (2 units) The more aggressive (C) position will not be required by most riders. For that reason they were not included with the kit but can be ordered additionally. In my extensive open road and back road testing, including riding the Dragon twice 2 up with quite a few times the inner wheel briefly off the ground they did not shift position at all. The units install or remove in minutes and this model will work for all 2013-2015 RT models with non-adjustable front suspension. It does not reposition the shock angles from factory. I tried them on a 2013 model and the rider came back and reported that his suspension improvement was immediately apparent. These units are directly manufactured by me by hand and come with a lifetime warranty against defects. The standing height of my RT was raised about 1/2" overall and no headlight adjustment was required. This product is based upon decades-old automobile suspension technology adapted to work on the Spyder.
http://dochumphreys.wix.com/roadster
in addition to or in place of...
Are these in addition to the sway bar? or instead of putting on a sway bar?
Well, I had a lot of Yaw on the bike going around corners. We also had a lot of turbulence when passing or getting passed by 18 wheelers. I installed Baja Ron's sway bar and was able to tell an immediate improvement n the passing 18 wheelers. Big difference. The sway bar did help with cornering, but it wasn't as stiff as I wanted it to be. We still had about 60% of that YAW motion like you were going to come off the bike. It was simply squatting too much to the outside in the corners. I did not notice it as much riding one up, but that was not my normally way of riding by about 95%.
At installing the stiffeners in the B position I found that the bike was much stiffer around corners. There was still Yaw, always will be with this type of ryde, but it was more in a factor of centrifugal force and not a soft suspension twisting the bike low on the outside.
i will tell you that the inner tire will leave the ground quicker on my setup, and that is understandable with stiffer springs, but I feel much more in control of the bike around curves now.
It's my guess that BRP made the front springs non-adjustable due to most of the ryders being more cruisers instead of performance ryders. It also allows the nanny more time to kick in with a softer suspension.
And, lastly, the springs should have been beefed up IMHO when they went to the heavier and wider 1330. The frame change is 2013 with the 998 had the same springs that are on the 2014 & 2015.
The closer the bike will be ridden to weight capacity, the more load on the springs, reducing the standing height, even causing negative camber, scraping during panic stops, even problems riding over curbs, etc..
I realize I really haven't answered your question very well, but in my opinion both products are excellent for what they do. If I had it to do over again, I would go with the sway bar also. If anyone ever removed their OEM sway bar and set it next to Ron's, there would be no doubt to change it. The OEM sway bar is a joke.
The shocks on the 2013 are of a smaller diameter than those on the 2014 and 2015 and I'm guessing that the spring strength has been increased on the 1330 to compensate for the increased weight.
I checked them with a micrometer and they are the same thickness. I did not check diameter, but to the eye they look the same and if the diameter is different it is not much. You have aroused my curiosity though. I will make a trip up to my friends' and get a measurement in a few days on his '13. Just for giggles, I'll also get a spring height so we can compare the 13's.
Thanks for posting that!
2014 RT series front left & right spring PN: 706001830 SPRING
2014 RT series front left & right shock PN: 706001549 SHOCK
2014 RT series rear spring PN: 706001542 SHOCK ABSORBER SPRING
2014 RT series rear shock PN: 706001552 SHOCK ABSORBER
2013 RT series front left & right spring PN: 706001359 SPRING
2013 RT series front left & right shock PN: 706001235 SHOCK
2013 RT series rear spring PN: 706001263 SPRING
2013 RT series rear shock PN: 706001262 SHOCK
Something has changed, not sure exactly what. FWIW, the 2013 RT and what appears to be the STS share the same front springs.
PK
You are right. Totally different numbers. As I said, the thickness of the coils are identical. I verified that with a micrometer several times. Only other thing can either be height or diameter unless they changed the composition on them and I doubt that. Thanks for posting.
Consider also, the rate of the spring is very dependent upon number of active coils and if there is any end conditioning. Number of active coils is and wire diameter are the main keys.
Measuring coil pitch is an easy way to compare with equal wire diameters.
The balance of a proper spring rate, proper preload, and suspension arm geometry is one formula for good handling.
PK
PK
You know, PMK, since the shock number is different between them also, there may be several factors involved here. My initial research was just to make sure my stiffeners would work on the 2013. Has anyone ever come up with an actual weight difference, engine and trans, from the 998 and the 1330?
IIRC the 2014 shock is a bit stiffer and made by a different source than the 2013 they are Sachs on the '14. Not sure who made the 13s but it is 1 possible upgrade to the 13 suspension the 14 shocks are plug and play and I believe have bigger pistons.
Doc's new farkle may be the affordable option to keep the front of my Spyder off the pavement on rough roads. If so, it's solid gold.
My initial point referred to the shock and not the spring. It would be interesting to see if the spring has also changed. Thanks for following up and it looks like you have a very viable product.
Got up to my friends' place and got some measurements on the differences on the front springs.
2013 - 7" total loaded height - Total number of coils = 8 - Outside diameter - 1.780 - Coil thickness - .0350
2014 - 7" total loaded height - Total number of coils = 7 - Outside diameter - 1.850 - Coil thickness - .0350
Looks like the '14 has a .070 wider diameter and one less coil.
Unless the shock has drastically changed and carries much more of the load, it seems to me a wider spring with the same thickness coil and less coils would give a softer ride. And it certainly doesn't allow for the heavier engine and trans. Still looking for the weight difference between the 998 and the 1330. I'm guessing at least 100-150 lbs.
Does anyone else see this differently?
922 lbs/in
913 lbs/in
Honestly need free length for proper rate, but this compares the two springs based on 7.0. What you measured is static net force.
PK
922 lbs/in
913 lbs/in
PK
So, PMK, what you are saying is the springs on the 2014 are SOFTER than the 2013 even though it has a heavier power plant? What engineering :joke: thought this would be a great idea?
