Freezedryman
Anyone know is the Pitbull shock relocators are helpful and why?
Jerry, one thing the re-locators do not do is shorten the working length of the SPRING......When you start adding spring spacers/wedges you are effectively removing the distance the spring will compress before it hits the stop....If you add enough of them you will have a " HARDTAIL " which isn't very comfort able......And with the re-locators you say " c " gets shorter....I believe PitBull's upper mount was done on an " arc " ( in & up ) and "c" which is the OEM shock remains the same length ( eye to eye ) it does not get shorter.....I know mine did/does. I'm not saying that ideally proper springs isn't the better way to go, just that the above is a better representation of the re-locator........Mike :thumbup:
Hi Jerry,
Re: Relocators: by changing the angle of the shock, "c" gets shorter but "b" gets longer
If 'b' gets longer ( and 'a' 'b' is still 90 * ) then 'c' also has to get longer. If 'a' 'b' angle changes to an acute angle, then you could be correct.
From the little that I know about the relocators is that they move the top of the shock outward; maybe a little higher but I am not sure on this.
Jerry Baumchen
:yikes:....Then you were the only one, I didn't hear of anyone else encountering that problem. They were designed as BOLT on NO trimming..........Mike :thumbup:I added the shock relocator brackets on my 2010 RS. Previous to that I had put a sway bar and Elka shocks on it. Each addition helped the handling. Defenitly recomend them for spyders older than 2013.
The one thing I found was that after adding the brackets I couldn't use the A arm covers.
...... The one thing I found was that after adding the brackets I couldn't use the A arm covers.
